Home > Technical (L322) > Ignition key will not turn
turbot
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Blade of ignition key came out of fob. Pushed blade back in to fob, key will now not turn in the ignition switch.
Post #630235 30th Apr 2022 8:29pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
The chip is still in the top of the key fob isn’t it? It’s a trapezium shaped black piece of plastic as seen here.
If that isn’t in the key then it’ll never turn. You could have also pushed the key into the fob too far so the tumblers are not tumbling.
Hope this helps?
Post #630247 30th Apr 2022 9:34pm
turbot
tb10 thank you so much, you could not have been more right. I went back to the car in daylight and found the chip in the footwell. Fixed the key immediately but the battery was flat as had drained overnight. A quick jump start sorted that.
I’m currently on holiday in the back of beyond with Mrs Turbot and this issue looked likely to derail our few days away.
We are both very grateful to you.
Post #630314 1st May 2022 6:37pm
tb10
No worries and glad to help. It could have been a very quiet journey home on the back of a flat bed had you not found it (but you would have saved the cost of the fuel though)!! Laughing
Post #630485 3rd May 2022 8:32am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
If you know someone with an appropriate RFID copier you can clone that little ID chip and epoxy it to the bottom of a generic key fob or drop it into an ebay 'cut from photo' BMW key fob.
I keep a cut key with an empty fob in my caravan's hidden key locker (can't start engine) and a cloned ID chip unobtrusively taped to the back wall of the locker.
Suitable RFID copiers and blank ID chips are just a few $ on ebay.
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #634669 15th Jun 2022 7:36am
