![]() | Home > Wheels & Tyres > Different sized wheels - why is this bad? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi all. Something has been bugging me for a little while and look to this forum to hopefully find an answer…
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Similar to yourself with my understanding…. And history of transmission wind up on different systems of 4x4….
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
Would you be covered by Insurence if you had an accident? probably not 2018 SE SDV8 4.4 Byron Blue |
I get that bit…. Though a space saver is a different size and that’s ok insurance wise. Suppose it’s about what a car is type approved with, from an insurance perspective.
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
My understand as to why its bad is a diff expects the 2 wheels to be driven or rotate at the same speed for the majority of its life. The 2 wheels rotate at different speeds when you go around a corner.
thanks for the responses so far
While I don’t see a reduced braking force as the car itself is providing the weight and pushing down on the wheel, there could be a reduced surface area from the smaller wheel?
If you run different sizes across an axle you will cause problems as highlighted by a recent thread in that if the ECU detects more than a 1kph difference on wheels it will interpret this as cornering and change gearbox behaviour I.e stop it changing up. Not sure different tyre sizes across an axle will pass an MOT either. If anyone has done the popular mod of fitting larger 255/55 R20 tyres from the L405 they will find themselves in this position if they have to use the spare which is a very good reason to replace it with a full size spare. As for diff wear I’d think the amount of time over the life of a car that it spends cornering or driving on non straight roads let alone the off road design would mean the diffs are pretty robust - but I wouldn’t want to test that assumption by running different size wheels. 2012 TDV8 Vogue (L322) |
The gearbox thinking it’s cornering is a good one! Does this happen if just one of the two wheels show a slower speed?
Variable dampers use accelerometers around the car for that, so they should not be affected, though I’m not sure if they do something under braking, but again, that’s prob the accelerometers again.
AFAIK the active damping is disabled under braking. 2012 TDV8 Vogue (L322) |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
A more basic and mechanical reason is this:
Cheers sako that makes sense.
The space saver should match the road wheels in rolling radius. 2012 TDV8 Vogue (L322) |
