![]() | Home > Technical (L405) > PHEV issue ? Short of breath on a long incline at speed ? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1395 ![]() ![]() ![]() |
Could it be a fuel issue? Are you using E10? Maybe worth getting the fuel system checked for contamination? Only Range Rovers since 1988 |
Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172 ![]() ![]() |
Hi CS, thanks for the response !
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 796 ![]() ![]() ![]() |
Similar car, never had this issue in similar circumstances, but maybe a visit to the dealer could help, as several transmission control module updates were performed, this year and last, for a low rumble while sitting at the red light... Yes, amusingly, the PHEV ICE engine sometimes runs during stops, and it is noisy, to the bewilderment of pedestrians... |
Hi Adara, thanks.
DKomoros Member Since: 09 Jan 2020 Location: Berkeley, CA Posts: 3 ![]() ![]() ![]() |
Was "EV" mode active? We live in the hills and if electric-mode is selected the throttle response is limited and the transmission almost refuses to downshift, even after the engine turns on. Manually deselecting the ev-button resolves this; downshifting with the paddle-shifters as your son suggested would also deactivate ev-mode.
It is worth trying. But I don't think the 'safe' mode is any help since even more power is required from the ICE.
We have been on a holiday to the Alps the end of june. No issue with powerloss. But honestly we didn't have a chance to go up a long incline with 130km/h like when it occured in France. I still use E10. I see no lower consumption when I did fill it up almost completely with it in Livigno ( € 1,72 / liter.. |
