![]() | Home > Maintenance & Mods (L322) > Thoughts? Has anyone upgraded the electrical BIG 3? |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
After quite a bit of YouTube and wider research into electrical starting/charging upgrades, there seems to be a lot of chatter about upgrading the so-called BIG 3:
Thanks for the input! I agree that engine block to chassis is the easiest and likely biggest ‘upgrade’ from the factory parts. I will be doing this as a minimum without any doubt! Andy
If it's not broken then why fix it? By all means check and clean any connectors but the wiring itself will be designed to carry more ( much more) than the maximum load as a designed in safety margin. 2012 TDV8 Vogue (L322) |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
As above, if anything I’d probably check and clean the connections, but unless I physically saw anything wrong with the wires I doubt I’d bother changing it all 2009 (2010 MY) 5.0 Supercharged Autobiography
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
I have no faith in that being the case, you just need to look at things like the mild steel brake lines to see examples of penny pinching. I would expect that the cables will be the absolute minimum that they need to be. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
I don't think that's true.
You might be right, I'm no electrician but my 1st 3.6 needed a new underbonnet harness fitted at 8 years old because of corrosion issues |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I replaced the loom on mine a couple of years ago as there was some internal corrosion on the cabling bit of a pig but all doable.
