Home > In Car Electronics (L405) > New Navigation unit Andriod based.
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi all, have just been told by Land Rover that Rover does not supply update Navigation discs for my very old seven year old car
HMMM!
So I have gone the road of ordering a new Andriod based unit from Alibaba.com from a company called Navihua,
I will install this unit myself. I have figured out how to run new GPS antenna to the outside of car quite easy really.
I need to do this as they use glasnost GPS system for signal. I dont know what Land Rover uses, but I will run this antenna
and it will be very discreet install so won't look out of place.
Navihua tells me that all factory functions will work with this latest version they are building for me. As they say R/H versions are special order.
I will wait till I get the unit and install and will let you all know how it goes.
As I have read all the early adopters of these types of unit have had a few problems.
Keep you updated when I get unit.
Post #627413 31st Mar 2022 5:37am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Can’t wait to see!
If it doesn’t work, here is the link to update your current NAV with a usb stick. Worked a treat on my 2013.
https://here.navigation.com/brands/Catalog...REEMEA/GBP Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #627460 31st Mar 2022 2:28pm
