Home > Technical (L322) > Pipe location HELP!!
GTTURBO87UK
I have fitted a new rad to my car but I knocked a pipe off when doing it and now I can’t find where it goes. One end goes onto an actuator looking part that’s in the centre at the fron near the bottom that is on a boost pipe, I can’t find where the other end goes. Please help me someone!
Post #627220 29th Mar 2022 5:12pm
mjdronfield
This is just a pic off the net…. Any help?
I know you can’t see it from the same angle….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #627225 29th Mar 2022 5:57pm
GTTURBO87UK
It would be below that
Post #627234 29th Mar 2022 6:40pm
JayGee
Looks like the vac connection to the turbo actuator. 2012 TDV8 Vogue (L322)
Post #627241 29th Mar 2022 8:12pm
Classic888
I feel your pain, in the past when this has happened to me I look at a LR online parts book and have managed to identify the item from there. Good luck.
Post #627243 29th Mar 2022 8:21pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #627249 29th Mar 2022 8:44pm
rjff
Nice one MJD just beat me to it. Bow down
GTT
Can I suggest as you are in there, clean and lube the connection from the actuator arm with the nut on it. It is known to seize, giving grief with the 2nd turbo actuation.
HTH Cheers
Richard
Gap IIDBT
Post #627250 29th Mar 2022 8:51pm
Baltic Blue
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #627252 29th Mar 2022 9:09pm
GTTURBO87UK
mjdronfield wrote:
Brilliant thanks for your help
Post #627266 29th Mar 2022 10:04pm
