Home > Technical (L405) > Minor leak, SDV8
ivo_markov
Belgium 2016 Range Rover Autobiography SDV8 Indus Silver
Minor leak, SDV8
Gents,
I noticed what seems to be a minor leak today, not sure if that leaky bit on the photos is the oil drain plug.
The car was at the dealer 10 days ago to sort out the bad smell in cabin issue, connected to the oil cooler/egr gaskets. They changed oil and coolant, and a bunch of gaskets and o-rings.
Long story short, I'm going back in the shop on Monday, just wondered if anyone has an idea what this could be.
Thanks!
Post #626836 23rd Mar 2022 6:54pm
mpirie
If it was in getting the oil cooler gaskets done, it's possible that you're seeing some of the spilled oil from the work done by the garage?
A good degrease and power wash may get rid of the stain.
Mike
Post #626837 23rd Mar 2022 7:25pm
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
got to agree with mpirie ,
if cooler gaskets been done, it may just be residue from repair running down back of engine. (seen it before ). covers off, degrease rear of engine and gearbox with brake cleaner and run it. hopefully this is all it is.
Post #626986 25th Mar 2022 4:33pm
ivo_markov
That was it.
Went back to the shop, asked them to look at it again. Mechanic admitted he couldn't unscrew one of the shield's bolts, so he couldn't clean up his mess. Did it anyway, degreased anc cleaned up, it's been fine since.
Thanks everyone!
Post #627790 5th Apr 2022 1:06pm
