Home > Maintenance & Mods (L405) > Front differential fluid change |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
New Oil is cheaper than a new diff or gbox
21st Mar 2022 8:34am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1382 |
Mine had its differential oil changed at four years/40,000 miles at my request. I was told that LR recommended it be done at six years, presumably about 60,000 miles (100,000km). It will partly depend on use when it is necessary. I have not had the gear box oil changed yet, but there will be threads on here about when it is thought wise to do it, I think maybe six years/60,000 miles. Maybe a search on the Getrag website would be useful too. Only Range Rovers since 1988 |
21st Mar 2022 11:44am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Obviously this is only my personal preference, I would change the oil in both diff's at the same time, usually earlier than recommended. Same with for the gearbox, do it earlier than quoted in the schedule.
21st Mar 2022 1:22pm |
ivo_markov Member Since: 21 Mar 2022 Location: Sofia Posts: 12 |
Yes, I wondered too. Probably because it has the active locking diff on the rear axle, as opposed to the normal one, and it is under heavier load, but I am only guessing.
21st Mar 2022 1:32pm |
There was no suggestion from the dealer that there was a difference between the differentials from a perspective of when to change the oil. Only Range Rovers since 1988 |
21st Mar 2022 6:25pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
The open diffs actually have a service interval of 160k miles or 10 years with the locking diffs at 80k or 6 years.
21st Mar 2022 9:38pm |
Here's a link to the servicing sheets for reference:
21st Mar 2022 9:42pm |
Many thanks! |
22nd Mar 2022 7:16am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
I have changed diff transfer box gearbox every 30k miles - I have had it from 60k it is now on 220k all running fine cant remember where I got the figure from but it was on here as a recommendation from somebody anyway for me it is worth every penny |
23rd Mar 2022 10:44pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
What is the oil that should be used for the diffs and transfer box? Current:
25th Mar 2022 11:42am |
Diffs = 75W90 GL5 eg. https://www.smithandallan.com/products/tra...l-gl4-gl5/
25th Mar 2022 12:05pm |
LR part numbers for rear fiff and transfer case oils are LR019727 and IYK500010. |
25th Mar 2022 12:47pm |
