Home > Technical (L322) > Advice on egr delete please, 4.4tdv8
GTTURBO87UK
I just got my ecu back from having a dpf and egr delete. Do I need to do anything either the egr or can I just plug the ecu in and go? Any help would be appreciated
Post #626345 16th Mar 2022 10:39pm
DrRob
Who did it for you? May I ask why you had it done? Were you experiencing dpf issues? I'm intrigued if the dpf is still in the exhaust, will it clog up given its physical construction? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626348 16th Mar 2022 10:57pm
mjdronfield
A fair amount of discussion on the subject here;
https://www.fullfatrr.com/forum/topic58100.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #626351 16th Mar 2022 11:03pm
GTTURBO87UK
Dpf is gutted out and deleted so no dpf, I just wondered if I have to physically block the egr or unplug it. I had a blocked dpf so thought I would fix it permanently, thought I would do egr at same time
Post #626352 16th Mar 2022 11:13pm
mjdronfield
Ah, dunno then. I wouldn’t suppose it mattered if you unplugged them then. Others will be along soon that are more knowledgeable on the subject…. But imagine if you unplug them and it throws an error… plug them back in….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #626357 17th Mar 2022 12:31am
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
ask the people who did the ecu ???? I am sure they know 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #626382 17th Mar 2022 1:50pm
GTTURBO87UK
I blanked the egr but intermittently am getting limp mode and fault code p042d-00. To mute knowledge it’s the temperature sensor that goes on the dpf. Surely they should have deleted that sensor when doing the rest? I have emailed them about it just waiting for a reply. Very frustrating as I thought this would permanently fix a problem
Post #626392 17th Mar 2022 4:48pm
GTTURBO87UK
The egr doesn’t need blanking I found out you just delete it on the map
Post #626897 24th Mar 2022 1:03pm
DrRob
Who gutted your dpf and remapped the ecu? Interested how it pans out....
Keep us all posted please Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626901 24th Mar 2022 1:44pm
GTTURBO87UK
I gutted it and welded it back up, I found a guy on the internet who done the map on the ecu. Now I’m averaging 30mpg and great performance too.
Post #626945 24th Mar 2022 11:31pm
DrRob
Gotcha!
Who did the remap? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626952 25th Mar 2022 8:52am
