Home > Technical (L405) > Autobiography 4.4 Diesel
piston
United Kingdom 2015 Range Rover Autobiography SDV8 Nara Bronze
When stationary with the engine at working temp I get a tainted fume smell inside the car with the heater on. I have also had slight smoke coming from the heater vents and around the wiper area. I’m assuming the heater is drawing in the smell from under the bonnet. There is no smell or oil leaks that I’ve seen under the car or within the engine area.
When normally driving the smell disappears. This must be due to the smell from under the car being drawn away by the movement of air.
The smell can sometimes make your eyes smart.
Any ideas would be appreciated thanks.
Post #626139 14th Mar 2022 11:16am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
This may be what you find?
https://www.fullfatrr.com/forum/topic35977...ooler+leak
Post #626144 14th Mar 2022 11:42am
knwatkins
I suspect oil cooler leak also. Fairly common on the 4.4 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #626187 14th Mar 2022 9:25pm
ivo_markov
Belgium 2016 Range Rover Autobiography SDV8 Indus Silver
Got this done last week, 600Euro job at the main dealer.
Whole bunch of gaskets and o-rings needed changing, not the oil cooler itself.
Post #626639 21st Mar 2022 6:08pm
piston
Thanks all.
It was a leaking oil cooler.
Post #629980 28th Apr 2022 9:25am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
all done now ? and back to normal i guess
Post #629992 28th Apr 2022 11:36am
