Home > Maintenance & Mods (L322) > Left foot accelerator - anyone amputees had this mod done?
carcathan
Bit of a strange query - but as a right leg amputee I'm just curious if any current forum members have a similar issue and have converted their cars to a second swicthable left foot accelerator pedal?
Aiming to get an early 4.4V8 L322 sometime this year.
I already have a specialist box of tricks that allow you to switch between the original pedal and a second BMW accelerator pedal. I'm presuming that by removing the right-footrest there will enough room to fabricate a way to mount the pedal.
Obviously you can get this done by a professional conversion company but as I'm buying a early fattie on a budget, it'll be DIY all the way. Smile
Richard
Post #625536 6th Mar 2022 5:35pm
Mr Tee
My best mate had this done professionally on a Peugeot a few years back, the pedal was effectively a flip down from a bar under the dash . Shouldn’t be too difficult, but the accelerator is effectively a micro switch under the pedal , there’s a plastic tube behind the pedal.
Post #625539 6th Mar 2022 5:54pm
Baltic Blue
I’ve seen an L322 with a hand throttle conversion, but sadly no pictures or info.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #625541 6th Mar 2022 6:15pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Look up BAS Vehicle Adaptations, Scott Bradley.
He's completed adaptations on anything from Ferrari's, Bentley's eye
Should be able to advise at least😉 Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #625545 6th Mar 2022 7:02pm
