Home > In Car Electronics (L322) > Hard audio connection to iPhone 10 pro, not Bovee
Walkzinho
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi all,
New boy here, just picked up a 2012 Westminster and will write a proper intro thread soon. One thing that I would like to get working is my hard iphone connection. I have a D4 which I just plug in via USB, obviously this isnt an option with the Rangey - I bought a 30-pin to female usb cable, then plugged in a male USB to lightning thinking that would simply do it, but it didn't recognise it.
Has anyone found out a way (or indeed a 30-pin to lightning cable) to hard connect? Or do i just go for the Bovee option?
Chris
Post #625157 2nd Mar 2022 4:55pm
JayGee
Just go for the Bovee. Bovee works but is sometimes unreliable when switching between calls and streaming on my iPhone (was faultless on my Android). I hate the autoplay on the iphone music app which can't be switched off and the fact that you can't shut off autolock when bluetooth connection is made like you can on Android. 2012 TDV8 Vogue (L322)
Post #625181 2nd Mar 2022 7:36pm
mpirie
I used the RR coily cable to connect my iPhone 8 with a 30 pin to lightning adapter, worked perfectly on my 2012 Westie.
Mike
Post #625182 2nd Mar 2022 7:49pm
RRABNara
2012 Range Rover Autobiography TDV8 Nara Bronze
@mpirie: have you put a 12v to 5v adapter before the 30pin to lighting?
if not is your iphone 8 charging when connected?
Post #625217 3rd Mar 2022 9:27am
Jayk69
i just use Bovee simple and reliable my phone just connects with no issues 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #625219 3rd Mar 2022 9:49am
rw90
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Bovee is the way ahead!
Post #626744 22nd Mar 2022 7:36pm
