Home > Maintenance & Mods (L322) > IID and Climate Seat Data
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I was reading a post on FB L322 group which included screen shots from an iCarsoft showing climate seat temperature and status. Plugged in my IID and I can't for the life of me find any climate seat related data. Am I missing something? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #624010 17th Feb 2022 5:18pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Would be a handy feature but don’t think you can see it on the iid tool
Post #624100 18th Feb 2022 4:44pm
RR2B
It seems not - I’m surprised iCarsoft displays more than IID Tool. Might drop a line to Gap... 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #624102 18th Feb 2022 4:47pm
RR2B
Prompt reply from GAP as follows (I'm still unable to find any live data):
Hello
The following is an excerpt from a fault reading on a L322 2010:
VIN
Model L322 - Range Rover 2010
Vehicle scanned on 21 Feb 2022 05:52:02
IIDControl 3.0.3 Build 89 Android - IIDTool BT V4.0 B2742
DCSM - Drivers Clim Seat
B122F-98 ( 28 ) Right seat back - Component failure - component or system is over temperature
( on 17-02-2022 06:29:16 at 170253 mi )
B1231-7A ( 28 ) Right seat - Mechanical failure - fluid leak or seal failure
( on 17-02-2022 06:29:15 at 170253 mi )
U0140-00 ( 28 ) Lost communication with body control module
( on 14-02-2022 17:48:08 at 170224 mi )
DSM-Driver Seat
B1332-87 (2F) Driver side - Rear seat switch pack - Bus signal/message failure - missing a message
( on 14-02-2022 16:55:53 at 170221 mi )
U0209-00 (2F) Lost communication with the seat control module B
( on 14-02-2022 16:55:52 at 170221 mi )
This ECU will provide fault data which is where you should start. If LR implemented Live Values for it, they will be in the tool. Keep in mind that they may be located in the HVAC ECU, complete list.
Best Regards
Patrick Meilleur,
Bachelor of Engineering
GAP Diagnostic 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #624552 23rd Feb 2022 5:47pm
