M62 Injector Wiring Diagram | |
Hi all,
Can anyone point me in the direction of a wiring diagram for the injector loom on a 2003 4.4V8 M62 engine? I've picked up a misfire on cylinder 5, put a friend's Snap On code reader on it, and confirmed as cylinder 5 injector faulty. Car runs perfectly on LPG but only on 7 with petrol. I've got rid of the plastic box that houses all the connectors as it just makes it impossible to diagnose properly if all 4 injectors have to be disconnected at once, swapped the wiring over between injector 5 and 6, fault stays with injector 5, so confident it is a wiring issue not the injector itself. Just want to check a diagram before I start getting too involved with tracing potential breaks in wires etc.
Thanks!
