Home > Maintenance & Mods (L322) > Speedo cluster repair - needle came loose
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi
I tried yesterday to replace the LCD-strip on my speedo cluster on my 2002 4.4i. Got everything together and tried it in the car and nothing worked. So I took it back inside to try and find out what was wrong. By accident I managed to pull the speedoneedle out, with part of the spring. So that needs to be replaced. Have anyone here done this job?
Post #623130 10th Feb 2022 7:10am
TDV8 Paul
I’m not an expert, but from what I’ve heard- once that happens you are in a world of hurt! Hopefully someone will be along to tell me im wrong 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #623173 10th Feb 2022 4:09pm
Steaky
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
A few folk in the E39 world have used http://www.clusterrepairsuk.co.uk to repair the fault you've created (no affiliation and I've never personally used them)
The E39/E38/E53 cluster design was used on the early L322 (02-05) so parts are readily available.
Post #623528 13th Feb 2022 9:43am
MariusRR
Have now managed to fix the LCD-strip completly, and separet the needle from the old pin. have ordered new steppermotor, so will give it a try and update when I am further in this idiotic quest
Post #623662 14th Feb 2022 11:00am
