Home > In Car Electronics (L322) > TV setup in an L322
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
TV setup in an L322
So the latest L322 I've got has a tv setup in it, I know years ago that it would have been an analog setup.
Doesn't anybody have a work around to get it working nowadays or is there a link to a thread on how to buy a certain part and fit it?
Thanks in advance.
Post #621570 27th Jan 2022 4:13pm
mjdronfield
It should work. They have all had digital tuners from about 2005/6 I think.
Will prob need retuning. Should be in the manual.
Assuming it’s the 2011 car in your profile.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621578 27th Jan 2022 5:20pm
kenneally_mark
I changed to a 2012 Westminster since, I've to update the profile.
The manual is a good shout! I forgot about that, thanks Smile
Post #621644 28th Jan 2022 9:35am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621668 28th Jan 2022 2:41pm
kenneally_mark
Excellent stuff thanks for that!! Smile
Post #621670 28th Jan 2022 2:55pm
i think ireland uses mpeg4 rather than the mpeg2 tuner the FF has..
if you cant get any tv after retuning then thats the reason... ... - .- -.
Post #621673 28th Jan 2022 3:40pm
kenneally_mark
Ahhh... is there any work around or part I can buy and fit? Thanks
Post #621677 28th Jan 2022 4:25pm
cant remember if there was a solution...do a search.. ... - .- -.
Post #621682 28th Jan 2022 5:11pm
Weegie
As Stan says, if the broadcasts are MPEG4 then there isn't a workround with the system you have. I tried. Sad
France changed from MPEG2 to MPEG4 and reception on the system was not possible. John
GAP iiD BT
Post #621697 28th Jan 2022 7:46pm
