![]() | Home > In Car Electronics (L405) > Disable Keyless Entry P400e - any suggestions, please? Fixed |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Took me a few goes to it to work if that helps. Quicker presses of the headlights and lock key seemed to be my issue. With door open and ignition off. Hope that helps 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
Thanks but didn't do the trick.... |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 800 ![]() ![]() ![]() |
So, the driver door MUST be left open during the procedure, ignition off and the keyfob pressing must be done INSIDE the car!
That’s exactly what I’ve done!
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
I did it to mine standing outside and it worked. |
Ha! I'll give it a go! |
Just to round this off, I found that if I unlocked and opened the driver’s door and waited about 30 secs, then did the key press thing, it worked.
