Home > Technical (L322) > '11 4.4 TDV8 - Coolant Leak |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Any oil or coolant leak nr the back of these engines and the first suspect has to be the oil cooler seals. Check your coolant expansion tank for oil contamination as well. 2012 TDV8 Vogue (L322) |
23rd Jan 2022 8:32am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Engine cover off, bonnet in service mode, remove pollen box with 2 nuts, grab a step and peer down back of engine and see if anything untoward going on around the oil cooler in the V. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Jan 2022 9:16am |
