![]() | Home > Maintenance & Mods (L322) > Rear back plates |
Ben84 Member Since: 13 Dec 2018 Location: Cornwall Posts: 86 ![]() ![]() ![]() |
Anybody?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
try a search or look in the wiki... ... - .- -.
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
Can't help directly, but there are various threads like this one [https://www.rangerovers.net/threads/l322-rear-brake-mud-shield-guard-replacement-how-to.268162/] on how to split and rejoin the back plate so you can fit it without taking the hub apart. |
There’s genuine ones on eBay for £155 for the pair but you can probably get pattern ones cheaper. |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
What makes you believe they need replacing mate? If it's for the hand brake there's an alternative that's a simple but very effective fix |
The plates are badly corroded. The brake shoe retaining pins are all but ready to pull through. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Get some small hole penny washers, these are also good for the bolt holes.
Already used washers as a temporary repair |
It is much easier to repair what you have rather than replacing! |
These little puppies here are your friends mate. Give you time too get the car ready to go in and have the rear hubs changed and the plates changed all in one go mate.
Do they use the same backplate for
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 193 ![]() ![]() |
I did this job to my car recently:
2002 - 2012 are all the same. ![]() |
Thankyou everyone for your help.
