Home > Maintenance & Mods (L322) > Range Rover ownership… the gift that keeps giving!!!
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
We love our fatties, but sometimes we have to wonder why!
So today, about a week after spending lots of £££ and many hours replacing various parts in the engine bay, I go for a drive on a cold Wednesday morning. The car has been warmed up a bit by the FBH and I set off only to hear an intermittent chirp / squeal.
It comes from behind the dash so I start working through all the things it could possibly be despite knowing instantly what it was… but attempted to find anything, ANYTHING else it could be! oh the images of a stripped dash flashing before my eyes teasing me! Big Cry
During the journey it got worse and more irritating. Setting the fan to high reduced the squeal and made it more bearable for the return journey…
Great, I am going to have to strip the dash and attempt to cut out the fan as per a few posts I’ve seen, and YouTube videos. Yippee Crying or Very sad
But wait, I have an MY12! I’m sure I read you can get to the fan from the engine bay? It’s just behind the pollen filter? I search online… nope it’s a dash strip. I search the RAVE manual… nope it’s a dash strip (I think, I’m struggling to find the heater core housing section).
Please someone tell me it’s easy and accessible through the engine bay Big Cry
I’m going to pull the pollen filter anyway as if I can see the blower through a duct I may be able to spray a lubricant to prolong the inevitable… wish me luck!
Oh the joys…
Anyway, rant over! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #620573 19th Jan 2022 12:41pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
i Changed the fan firday using this video on my 2012 4-5 hours not to hard realy if you watch the vid and take your time, id fist check to see if the fan spins easy by removing the pollen filter housing turniing the ignition on, turn fan on this opens the outside air flaps you will see the fan running and also be able to hear if the squeek is indeed coming from the fan, turn ignition off and the flaps stay open a short while so you can feel the fan to see how easily it moves.
this is a link to my post with the video in it
https://www.fullfatrr.com/forum/topic62215.html 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #620598 19th Jan 2022 6:12pm
Ffrr-lover
Cheers furnitureman, oddly enough I was just watching that very video!
So it’s looking like a days work, all going well. And about £110 for a new blower and fsr. Not as bad as I though…
That’s a good shout about checking the squeal from behind the pollen filter. I’ll do that just to be sure it is the fan (I know it is… but I’ll take any chance I get at it being something different and hopefully easier!) Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #620599 19th Jan 2022 6:21pm
Furnitureman
Got my blower from advanced factors i think around £80 i think also you can get the forum discount and it has a 2 year waranty, if you decide to go ahead with the change drop me a PM there are a few tweeks to the video that will make things easier and the main one is getting a multi cutting tool much easier than the dremel 2012 Range Rover Westminster 4.4 TDV8
Post #620603 19th Jan 2022 6:26pm
Ffrr-lover
Cheers for that! I’ll let you know when it’s time.
I have one of these… is that what you mean? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #620605 19th Jan 2022 6:38pm
Furnitureman
Yes mate we use those at work, 2012 Range Rover Westminster 4.4 TDV8
Post #620607 19th Jan 2022 6:40pm
Brerfox
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
whoa what did you have to cut? I followed the video undid the clips then the thee bolts that held the fan and then just wiggled the fan out.
Post #620696 20th Jan 2022 3:37pm
Brerfox
ah just watched your video. when you take out the two middle clip on plastic vent tubes you can also take out the ones on each side when you take out those that whole jeep grill looking piece also unscrews and comes out which means you can take the fan out move it towards the back of the car turn it sideways and it comes out.
Post #620700 20th Jan 2022 4:03pm
Furnitureman
Surely if you followed the video you must have cut something as the fan won’t come out due to the cable tray and the obsolete impbaliser bracket 2012 Range Rover Westminster 4.4 TDV8
Post #620708 20th Jan 2022 4:53pm
Furnitureman
Sorry just read your second post, I wish I’d have known that before I started cutting 😂 2012 Range Rover Westminster 4.4 TDV8
Post #620709 20th Jan 2022 4:54pm
Ffrr-lover
I’ll put this back in its box then! Laughing Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #620716 20th Jan 2022 5:43pm
Ffrr-lover
It died. Went to go out in the car on a cold frosty morning, so used the FBH to defrost the car… but when I went to get into the car I found it to still be frosty.
so I start the car, push the buttons to blow at the screen… and nothing. No air movement at all.
Well, there goes my plan to lube the fan to try to get a bit more life out of it!
Off to advanced factors to order a replacement blower and fsr. And pry bar from Amazon. That’s next weekend booked up! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #620930 22nd Jan 2022 12:51pm
Ffrr-lover
Well I’ve started… just under 2 hours in.
I don’t yet see how you can gain access without cutting, but have stopped for food and coffee and will crack on! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621775 29th Jan 2022 12:16pm
kevinp
I don't envy you doing that at all mate. Keep the pictures coming though.
Post #621789 29th Jan 2022 2:32pm
Brerfox
yep nearly there the two vents below come off and the facia with the start stop button comes off then the plastic tubes just pull out, might come out easier if you squeeze them lengthways? then the jeep grill type thing unscrews the hardest screw is the one on the right as you look at it. how are your hands looking? then three spring clips and the front panel of the fan folds towards you and comes out
Post #621805 29th Jan 2022 5:18pm
