Home > General (L405) > LWB.....am considering going to look at this...... thoughts?
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
https://www.lowtonmotorcompany.com/used-la...re-3997527
Post #620270 17th Jan 2022 9:20am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
My only comment is that it seems a bit expensive for a 2014 model. Had a quick look on Autotrader and there are a few AB's with less than 50,000 miles for under £40,000
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #620275 17th Jan 2022 10:20am
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
There's a 2 year gap in it's MOT history (tested Sep 18 and then Dec 21). Worth checking to see if it has been serviced correctly. 2017 SDV8 Autobiography
Post #620279 17th Jan 2022 11:14am
its looks like a nice comfortable ride for the peeps in the back, but will you benefit?
also consider parking in multi-storeys and supermarket carparks.. ... - .- -.
Post #620280 17th Jan 2022 11:39am
andyleeds
the LWB's seem to be about 10 grand more than the non standard etc?
parkings not an issue, will be used for the holidays and taking me to the golf club, drive from yorks to alps might be a little more comfortable Wink
i will check out the history and see what its had done etc? im assuming if it comes back as main dealer we should be in the clear i seem to remember reading that the 4.4's as fairy bomb proof?
Post #620286 17th Jan 2022 12:36pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
these are quite nice too:
https://www.autotrader.co.uk/car-details/2...amp;page=1
Post #620290 17th Jan 2022 12:47pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
LWB is nice to be driven in, although that seems a pretty standard seat setup to me, and a compromise to drive. I'd stay clear of them unless you buy it for chauffeuring work.
Post #620368 18th Jan 2022 7:54am
