Home > Maintenance & Mods (L405) > Oil level sensor not available
Tuckmeister
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi Guys have a 2013 l405 4.4 can't get oil level reading.?? On my last car l322 5.0 no problems always worked..
So taken car to RR specialists use all genuine parts replaced faulty oil sensor big job strip down etc...£900 later... To now be told ECU has fault ?? Even though oil level sensor was told the issue & ECU would be expensive.. but surely this would show up on diagnostic prior to oil level sensor being done ?? Or not... Surely ECU fault would cause more issues than just oil level sensor not giving oil level.. anyone else had this problem or advise..
Can ECU be reprogrammed or replaced with secondhand one & then cloned with mine ??? Any advise
Many Thanks 👍👍👍 Big Cry Range Rover P38
Range Rover L322 Vogue
Range Rover Sport 4.2 SC
Range Rover l322 5.0 V8
Range Rover L405 TDV8 4.4
Post #620144 16th Jan 2022 10:17am
knwatkins
Are you sure it's an ECU fault and not the turbo actuator?
The ultrasonic oil level sensor is mounted inside the sump and they are known for going faulty and allowing oil to seep into the wiring harness. Once the oil is between the copper conductors on in the wiring, it tracks up the inside of the cables and ends up in the turbo actuator electronics causing it flood with oil and fail.
There is an updated bridging harness to prevent this which I fitted to mine, here:
https://www.fullfatrr.com/forum/topic57501.html
Land Rover have issued service instruction N375 to cover this issue. See here https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #620149 16th Jan 2022 10:40am
Tuckmeister
Hi knwatkins...
Thanks for information.. car is still in with Garage had sump strip down etc, & replaced now they say it's ECU fault.. will go back to them on Monday with this information.. Thanks for your advise..👍👍👍 Range Rover P38
Post #620168 16th Jan 2022 12:19pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
@Tuckmeister
When I first got my L405, I had the same issue (fortunately fixed under warranty). I am pretty certain that it showed a fault code on my IID tool.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #620265 17th Jan 2022 8:40am
Kot
Are you sure N375 has been done on your car?
I had the same symptom --unable to see oil level "not available".
It started 4 months earlier, under warranty they replaced the turbo actuator as I had P0045 fault they also told me that N375 was complete on my vehicle!
4 months later I had the following codes showing, when oil level was not available.
P250B-37 Engine oil level sensor - circuit high. diagnostic device shows 11 litres!! and 6%
P250B-29, P250B-87 Engine oil level sensor - circuit range/performance
P0196-29 Permanent Engine oil temperature sensor circuit range/performance
LR Assist thought it was N375!
Dealer had the car for 3 days
Like squeezing blood from a stone, never did get a clear answer of what the real problem was, the girl at the desk said--
"There was a small Oil leak from the engine block from oil level rubber bung? (yet no oil showing on block paving?) was told it was contained by the protection tray. Bung was replaced! level now working. It seems this was disturbed during N375v2 whenever that was last done? Or did they fail to do it 4 months earlier!! or was it not done correctly? was my question--of course that question was never answered. 2018 SE SDV8 4.4 Byron Blue
Post #620271 17th Jan 2022 10:06am
Tuckmeister
KOT
This is what I am trying to find out as had mine sensor done & still not working now being told a fault in ECU need a new ECU..
Which I think is Rubbish.. when I mentioned N375v2 fitted
Yeah I am sure it was.. so I have left car with them to make sure it's fitted instead of guessing...
How much is ECU replacement ???? Bow down Big Cry Range Rover P38
Post #620421 18th Jan 2022 3:56pm
