![]() | Home > Technical (L405) > L405 Light Oil Leak at Rear |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
There are no oil feeds to the air suspension. As it's air suspension, they have air feeds, not oil (hydraulic).
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
If it were me i would change the pipes for a flexible hydraulic hose... Much easier to install |
That's a good point Craig. It won't rust then! Kev
Exactly... |
Etype1961 Member Since: 14 Jan 2022 Location: Gatehouse of Fleet Posts: 5 ![]() ![]() ![]() |
This problem has now been sorted. I bought the complete feed and return pipe set from Land Rover, around £550 GBP. I had my local independent garage undertake the repair, not my usual JLR dealership. Usually my cars have all their work done at the Land Rover dealership, but calling them and enquiring in to this job with the service manager I was told this is a 20 hour job, best case scenario. They went on to inform me that because so many items had to be stripped down in order to access the complete pipe assembly it could well run in to double, plus additional parts that would ‘break’ in the strip down. Hence my decision to ask my (reasonably) local garage to do the job. They did the complete job in around 10 hours, without’breaking’ anything in the process.
Glad you got it sorted. So what pipe assembly specifically was replaced? Kev
It was the the complete feed and return pipe assembly, I believe feeding the Dynamic Response rear active anti roll bar. Range Rover SDV8 Vogue SE - 2014
Sorry I should have mentioned, this is a dual pipe assembly, feed and return I assume. Range Rover SDV8 Vogue SE - 2014
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
Now you’ve changed them, give them a good coat of waxoyl or similar to save them corroding again, especially if your keeping it. Very common on this model |
Good point, thank you!
To be honest, IMO the SDV8 is the best of the L405 bunch. They’re not flawless but generally are holding up well due the all alloy body. I’ve given mine a good waxoyl over all the metal parts underneath to keep it in good order.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Is this what you do on customer cars when you replace them Craig? Any further insight? Do you replace them front to back with hydronic hose or join and replace just the required section? Have been looking at a friends L405 for him, and can see that his are in bad shape where exposed towards the rear. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 28 ![]() ![]() ![]() |
I was shocked (and appalled) at the rusted state of the ARC on a 5 year old car. Is it best to use Kurust or something first prior to Waxoyl? Could you let me know the name of your garage, always nice to know where the good locals are. Cheers |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1304 ![]() ![]() |
I guess the Scottish roads get a lot of salt in the winter and a contributing factor I would presume. I wonder did they change these mild steel pipes on the L460? 2018 SE SDV8 4.4 Byron Blue |
