Home > Technical (L322) > Trans fail safe
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Trans fail safe
Have this message at start up but clears if I restart. Battery good and I’ve stripped xyz switch and all looked good. Box changes fine. Anything in the box that fails to cause this?
Post #619620 11th Jan 2022 8:01pm
RRPhil
A faulty transfer box shift motor potentiometer is a possible cause (although, usually, it's the battery). Does the transfer box shift into low range and then back into high range okay?
Phil
Post #619659 11th Jan 2022 11:18pm
When you say "the batteries good" how have you checked sir?
Post #619663 12th Jan 2022 12:25am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Phil & Craig are right about the battery.
I'd take it a bit further and advise you to change it if older than 2 years, regardless, before looking into anything else.
Those times you get the message, upon turning the key, do you have selector position indication displayed on the dash (P or N) ?
I had the same issue and was so convinced it was the xyz switch that I purchased another one, luckily at a bargain. My battery appeared to be holding its charge until it didn't...New battery and all was magically cured Thumbs Up
Post #619669 12th Jan 2022 7:08am
Jimes256
Battery is new and I’ve charged it to make sure. Not sure about lights on dash. Wonder what happens to potentiometer.....
Post #619758 12th Jan 2022 9:20pm
Jimes256
I wonder what goes on the potentiometer to only effect it when cold? Put the inhibitor back on and still the same. No display on dash.
Post #619889 13th Jan 2022 8:26pm
