Home > Maintenance & Mods (L405) > Brembo 6 Pot front brakes squeal / noise when braking
Ben Ball
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Just wanted to let you folks know that after many months of suffering annoying brake squeal under light to medium pressure I have finally found a brake pad that is silent under normal conditions. I have tried Brembo Pads, Genuine Range rover pads and Pagid Pads. Finally I have cleaned down the front brakes (again) and fitted Terrafirma Ceramic Brake pads. The car is now silent when braking from any speed and under any pressure. As far as i know the brembo 6 pot front calipers are quite troublesome when it comes to generating unwanted sound. I really struggled to find a solution to the problem so I thought I would become a member and share this information as I hope that it can save some of you guys time and money if you have squeaky brakes (like a london bus or taxi cab sound, high pitch).
All the best!
Post #627617 2nd Apr 2022 6:17pm
