Home > Maintenance & Mods (L322) > Retro fit Aux Input
FactoryPilot
Retro fit Aux Input
Hi guys, new to this forum but owned many, many RR's over the years.
Anyway, we have a 2006MY FFRR which has the Jag engine, new front end, touch screen Nav, etc, but it has the older style dash without terrain response and crucially no Aux input anywhere.
The car is a 4.4 V8 Vogue, but in my other newer 2008 TDV8 Vogue SE this has an Aux Input behind the centre console, so I can plug in an iPod via a headphone jack lead.
I just wondered if there is anyway of retro-fitting this set up to my other earlier RR. Will the wiring be there under the console and is it just a question of doing a bit of choping and soldering?
Or is there an easier way of modifying the wiring so that I can link a headphone jack cable into the Sat Nav/Audio system.
Any help much appreciated.
Post #4321 29th Mar 2009 8:06pm
dantheman
Factory Pilot,
Ditto... I've exactly the same vehicle and the same problem. I spoke to a guy about a month ago that sold an ipod/mp3/audio conversion system (v similar to a Denison 500: which apparently isn't compatible with FFRR) and was to fit and test one - but never got back to me.
Sorry I can't be of any help presently.
Post #4332 29th Mar 2009 11:10pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Try Prestige Audio in NW10 for a fitted solution or NavTV .com for a DIY solution Thumbs Up
Post #4337 30th Mar 2009 6:22am
Andy
Www.incaripod.com
There is one on this site for range rovers, which plugs into the cd player 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #4341 30th Mar 2009 7:32am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Wouldn't it be easier to buy one of those convertors that plugs into your iPod and generates an FM signal, so that you just tune your radio into the frequency it generates and so can play it through your sound system? Or do you want something more permanent? Maplin do one for £70 but they are as cheap as £20 for a basic one.
e.g.
http://www.maplin.co.uk/Module.aspx?Module...doy=search
Cheers, Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5186 25th Apr 2009 11:31pm
