![]() | Home > Off Topic > Any iPhone Bluetooth experts here please??? |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Forget the wifi connection for Apple CarPlay, that will stop Apple CarPlay activating wirelessly.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
While I have no experience of these CarPlay devices, I have spend some time investigating following interesting posts by fellow members.
I have been thinking about this whilst in the shower (rock n roll I know!) and what sticking for me is that I didn’t think CarPlay used Bluetooth? It uses either wired, or it’s own wireless connection? This should mean that the android device is free to connect to the car via Bluetooth? If you turn off Bluetooth on the phone, can you still connect to the CarPlay unit? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
If it’s using proper apple CarPlay protocols it utilises Bluetooth LE to establish “awareness” and then follows up with a direct WiFi connection for the wireless interaction.
I will add this to the original post too… |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
under bluetooth settings the top item gets priority so if you want 'craigs phone' to be connected before carplay then make sure its the first ..
The first where please Stan? |
in the BT list.. ... - .- -.
Wireless CarPlay uses a combination or Bluetooth and WiFi. There is no way around that except for going corded with a lightning cable.
Just been having a mooch around on line and it would appear it could be called ‘Spotify connect’ ? But now I need to workout if it’s possible to make the car connect automatically before the CarPlay? |
It is above it alphabetically on the list Stan, but the CapPlay still takes priority over the car… |
What is DAC please Blackdog? |
ah ok..
Sorry a DAC is a digital to analog converter. It always happens somewhere along the path for sound to be broadcast by a speaker. As such whilst keeping it digital is generally a good thing, it is still important to understand where the conversion occurs and which part is actually the best for that.
