Home > Maintenance & Mods (L405) > L405 3016 4.4 v8 diesel intermittent low coolant warning
Drksde
Hi guys for the last two days I am intermittently getting a low coolant warning on the dash. The oil intercooler was changed under warranty in May 2021, and I was wondering if this is part of the same system?
Is the car safe to drive?
I can't quite work out where the fluid should be in the coolant reservoir.
On cool engine when looking inside I can see pinkish liquid right at the bottom of the reservoir below a small oval hole? I can see any max or min markings.
Think will call the LR dealer in Surrey where the car was repaired under warranty tomorrow to book it in for a check.
Any advice would be much appreciated thanks a lot.
Post #618550 3rd Jan 2022 1:18pm
Landphil
The cold max level is when the coolant is just on the top level of the oval hole.
There are max and min lines visible if you remove the black plastic cover on top of the reservoir
Post #618559 3rd Jan 2022 3:16pm
As LandPhil says above...
And to add, you shouldn't drive the car with that warning unless you have a competent person check it over... Running out of coolant can cause a HUGE amount of damage sir... Thumbs Up
Post #618561 3rd Jan 2022 3:28pm
Drksde
Thanks for the advice. Will leave the car on the drive till I get landrover technicia round to have it checked over.
Post #618572 3rd Jan 2022 3:59pm
