Home > Wheels & Tyres > Tyre pressure change for larger wheels
jazzdude
Cyprus 2007 Range Rover Vogue TDV8 Java Black
I have 285/45/22s on the car curtesy of the previous owner and am wondering if they should be inflated to the same pressure as shown on the door jamb chart.
Strange because I tried this site https://tiresize.com/pressure-calculator/ and it says the pressures should be reduced to 28fr and 31r.
I reduced the tyre pressures accordingly and am not surprised to find that it goes over bumps and manholes much smoother but I must say I'm quite surprised.
Does this sound right?
Post #617665 27th Dec 2021 1:04pm
This is from an L405 but shows the same pressure for all sizes under normal load and only a small difference under heavy load -
Post #617683 27th Dec 2021 3:09pm
jazzdude
Although those tyres on the chart, even though they are different sizes, I would have thought that they all have the same rolling radius.
According to a tyre size comparison, the wheels and tyres on my car have a 7% larger diameter and are 12% wider. Apparently with more volume of air the pressure needs to be less.
I suppose the only way to know for sure is a chalk test but I am wondering if anyone found the same results, ie lower pressure with larger tyres.
Post #617698 27th Dec 2021 4:14pm
JayGee
I would say to compensate for more compliance in a higher sidewall the pressures need to be a bit more? 2012 TDV8 Vogue (L322)
Post #617728 27th Dec 2021 6:22pm
Rob99
285/45R22 I don't believe is a standard LR tyre size so will be significantly different and makes your speedometer way out, compared to standard.
As in Alistair's picture, for 22inch wheels the standard sizes are 275/40 and if you increase the width you need to reduce the aspect ratio to keep tyre diameter etc consistent. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #617731 27th Dec 2021 6:34pm
jazzdude
I know they are not a standard tyre but they are brand new Contis and I feel I should use them until they wear out rather than throw away €1500 of good tyres.
I have adjusted the suspension with Gap tool so there are no clearance issues, just want to set these up properly.
Post #617732 27th Dec 2021 6:44pm
JayGee
I'd simply adjust to taste - too high a pressure and the ride will get harsh and too low a pressure and the handling will get unpredictable. Main thing is to have higher at the rear to preserve some directional stability. Worth also dialling in the new size into your CFF - instrument pack to get both a usable speedo and help the ABS and gearbox behaviour. The rolling radius - ABS is easy to work out but the last value in the list is for the speedo and you lower the number when you increase the tyre size. On my 255/55 R20 I had to drop digits and you may have to drop 4? 2012 TDV8 Vogue (L322)
Post #617733 27th Dec 2021 6:55pm
jazzdude
Unfortunately, the Gap tool does not have this setting on L322s. My speedo reading and fuel consumption are thus lower than they should be due to the slower rotating wheels.
Post #617734 27th Dec 2021 6:58pm
JayGee
Ah the settings must be just for the 2010 facelift models?
At least you have a V8 to overcome the effective later gearing. 2012 TDV8 Vogue (L322)
Post #617736 27th Dec 2021 7:00pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Re: Tyre pressure change for larger wheels
I’m running the same tyre size and found the same site for calculating the tyre pressure. I was also surprised to find the pressures were lower too!
I found a handful of other sites which also gave the same results.
I started on higher pressure (from when the tyres were fitted) to those figures, tried those pressures, and settled on a slightly higher pressure. I was using rolling noise as my guide as I didn’t find any real noticeable difference in ride quality. I am, however, running on cheap tyres at the moment…
Out of curiosity, how do you find the ride handling on these tyres? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #617749 27th Dec 2021 9:22pm
jazzdude
As I said they are Continentals and I was originally running them at the pressure as shown on the door, ie 2.3 /2.5. It was crashy over the bumps which is why I looked further into the pressures.
I only tried the lower pressures today and the car instantly felt softer over the speed bumps and potholes but I have not gone out onto a highway yet to see how the handling is.
To be honest, if this size works out I'm considering sticking with them as they offer the same amount of tire wall height as the 255/50/20s that are standard. I am hoping that the replica Overfinch alloys that the car came with will thus not be too fragile and might resist the odd pothole.
Post #617751 27th Dec 2021 9:33pm
Vogue
Some RR’s including some SDV8’s, SVA’s and SVR’s and also some Discovery 5’s have been delivered with 285/40/22 Conti’s from the factory. Continental also mark the Conti Silent 285/40/22’s with the LR mark on the sidewall. I’m not entirely sure if fitting this size was due to a shortage of the standard 275’s or there was a specific reason for it - all were Continentals and no other brand.
FWIW, the 285/40/22’s are an exact diameter replacement for the std 255/55/20’s, the 275/40/22’s are slightly under size. The speedo for 285’s therefore reads the same as std 255/55/20’s - in my experience this is around 3mph over.
I also have a set of 285/50/20 AT’s for winter / shooting season - these are significantly bigger diameter than standard 255’s / 275’s and the speedo still reads slightly fast. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #617754 27th Dec 2021 10:11pm
jazzdude
I've been driving around all morning with the 28/31 pressures and although the car feels smoother, the steering is heavy.
I am trying out a midway point between the above and the door pillar spec to see how that goes.
Post #617791 28th Dec 2021 12:20pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
You've got overfinch wheels on yours by the looks of it. Heres a pic of the overfinch tyre pressure sticker on door pillar of mine, you could try these pressures and see what you think.
Post #618194 31st Dec 2021 5:51pm
Very easy to find the correct tyre pressure for any tyre on any car......
Inflate the tyres to the pressure you think....
Drive 20 miles down a motorway.
Stop and immediately check again.
It should be 4psi higher than the first pressure.
Drive home and let them cool overnight before trying again....
Ambient temp should be 15-20C
Thumbs Up Pete
Post #618216 31st Dec 2021 7:43pm
