Home > Maintenance & Mods (L405) > Should I be worried about this?
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Had this fault come up 3 times now.
Apparently there’s a service bulletin about it. And all that needs doing is removing a connector - so wire goes straight to destination.
Thanks to GAP IID can clear the fault and get rid of “Restricted Performance”.
But is it worse than the service bulletin suggests? What do I put here then?
Post #617055 20th Dec 2021 9:31pm
GAC23
Any ideas or comments very welcome.
Thank you. What do I put here then?
Post #617113 21st Dec 2021 2:06pm
Sorry - I've never read the faults on mine - ignorance is bliss Whistle
Post #617153 21st Dec 2021 5:46pm
GAC23
I only read it as “Restricted Performance “ and the red warning triangle came up.
Otherwise I agree about ignorance. What do I put here then?
Post #617202 21st Dec 2021 11:34pm
Chalky
I agree with Alistair and GAC23, or turn the radio up Rolling with laughter All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #617232 22nd Dec 2021 11:18am
GAC23
I'd laugh about it too ...
... but having the car go into Restricted Performance mode while you're driving is no fun, What do I put here then?
Post #617233 22nd Dec 2021 11:21am
Chalky
I agree with that, but whenever I have a car problem that's what my garage always says..."Turn the radio up!". They know I am not technically-minded so it's probably the best advice! All LR cars from 1984
Post #617234 22nd Dec 2021 11:23am
GAC23
It's "sound" advice Rolling with laughter Rolling with laughter What do I put here then?
Post #617235 22nd Dec 2021 11:25am
Chalky
Thumbs Up Thumbs Up All LR cars from 1984
Post #617237 22nd Dec 2021 11:32am
Kot
Re: Should I be worried about this?
Are you going to enlighten us with the service Bulletin details? 2018 SE SDV8 4.4 Byron Blue
Post #617240 22nd Dec 2021 12:02pm
GAC23
I don’t have them.
Was hoping my post would have a helpful person point me to the bulletin and / or …
… tell me not to worry, it is only as bad as the bulletin suggests.
I’ll keep you posted as I find out more. What do I put here then?
Post #617297 22nd Dec 2021 9:50pm
Optimaplus
Hi my car had this it would go into limp (redistricted) perfomance mainly when driven hard
There is a service bulletin referring to small loom from fuel pressure sensor you can buy new loom remove end thats joins orig loom and end from loom and join together
Its resistance in plug and will get worst over time
Post #617851 29th Dec 2021 1:22am
GAC23
Thank you!
This sounds exactly like what I was told about the bulletin.
It’s booked to be looked at - and I hope fixed - first day back after the holidays.
In the meantime I have my GAP IID permanently plugged in so I can clear the fault when it occurs. What do I put here then?
Post #617870 29th Dec 2021 10:32am
GAC23
The technical bulletin is LTB01083
It's here:
https://www.fullfatrr.com/gallery/albums/u...B01083.pdf
... and it describes perfectly what I'm suffering.
Not for long though, FF at indy's on Tuesday. What do I put here then?
Post #619127 7th Jan 2022 4:19pm
GAC23
... and all sorted Smile What do I put here then?
Post #619801 13th Jan 2022 11:34am
