![]() | Home > Maintenance & Mods (L405) > Oil change Vs sump/filter replacement Vs megaflush? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
My personal view - based on admittedly limited experience - is that I will continue with "standard" drain & fill procedures NOT using megaflush or similar.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
The can of worms has been opened |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Changed mine using the drain method.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 255 ![]() ![]() ![]() |
From the horse’s mouth:
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Drain and refill here |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
I’ve never had a gearbox problem |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
I have personally flushed well over 1,000 gearboxes, between ZF 6/8/9HP and the AW boxes (FL2/Evoque), some with filters and some without, and we've never had an issue |
Exactly! Don't Megaflush a box with issues as it seems to make it worse. Deal with the issue. Common sense. I see Megaflush as part of preventative maintenance program on a box in good condition and wanting to keep it that way ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I did sump change and 3 x full drain and fills to change all the fluid
Follow up from the horse's mouth:
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Mega Flush - Done it as preventative maintenance, best way to change oil... |
I'd love to see a flushing machine that recycles fluid. That would defeat the whole purpose of a flush ![]() Our machine was not particularly cheap, but it is very clever It measures the pressure and flow of the outgoing oil, and refills using the same flow and pressure It is clever enough to have the feature of Zero Cross Contamination, where it purges the lines of any old fluid and replenishes with new fluid (handy, as qe flush lots of 6/8/9HP boxes, and also the Aisin Warner boxes in the Evoque and Freelander 2. Both use a very different oil, and are not compatible) Also, not keen on chemical flushing, but have used it to good effect in the past... It sounds as though ZF have given a blanket "not advised" as there are too many variables with cheaper machines, which can cause damage ![]() |
