Home > Technical (L322) > L322 no power to injectors
Jayk1993
United Kingdom 2004 Range Rover Vogue Td6 Stornoway Grey
Hi I'm new to the page after recently buying a 2004 l322 td6 that I'm having a few issues with the main one being that it now will not start the engine will crank but does not even try to fire up had the rac out to it yesterday who told me I'm not getting a signal to my injectors for them to fire but it's showing no fault codes is this likely to be the ecu or maybe just a bad wire somwhere thanks in advance for any help on this
Post #616021 12th Dec 2021 6:01pm
wayneg
If you are not getting sufficient fuel pressure from the electric fuel pumps the injectors won't fire. The most common cause is the pump by the NSR wheel. Take off the cover and give it a decent wack. Cheap and easy to change. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #616273 14th Dec 2021 7:21am
Jayk1993
I had ruled this out as I Took the cover off the pump and had a listen its definitely working although now you mention it the pressure isn't great would low pressure on the pump stop the injector harness receiving power though was leaning more towards ecu or maybe crankshaft sensor but would make sense if this is the case
Post #616278 14th Dec 2021 8:08am
Jayk1993
Another thing to mention I reluctantly let the rac try a squirt of easy start and it seemed like it was going to but still didn't start
The injectors are OK it's the harness from the ecu not getting power
Post #616282 14th Dec 2021 8:25am
wayneg
There are two electric pumps, one in the tank, the other outside. If there is plenty of fuel in the tank it should get to the 2nd low-pressure pump ok. This should pump fuel at around 4bar to the fuel filter and onto the mechanical high-pressure pump. There is a sensor on the fuel filter that tells the ecu there is good fuel pressure, if no then as far as I know the injectors will not fire. Any decent diagnostic tool should show the low-pressure reading. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #616293 14th Dec 2021 9:27am
Jayk1993
I pulled the pipe off the fuel filter and cranked the engine and fuel came out but only a trickle sounds like I've overlooked the pump to soon then didnt show any codes for fuel pump when rac plugged in though is there any way of testing if its the pump before replacing ? Does jumping the relay give it more power or is that just for when it's not working atall
Post #616304 14th Dec 2021 10:45am
wayneg
What did your diagnostics show the pump pressure to be? If you have no diagnostics you need to start guessing and replacing parts. 1st part to replace is the out of tank low-pressure pump, see link for a cheap version,
https://www.ebay.co.uk/itm/174940750137?fi...SwOghfvQNr 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #616313 14th Dec 2021 11:41am
Jayk1993
He never told me what the fuel pressure was unfortunately just that it was showing no codes trying to avoid just throwing parts at it but havnt got the gear to test it myself
Post #616319 14th Dec 2021 12:07pm
Jayk1993
Looking at the link you have sent this isnt the pump I have checked I've checked the in tank pump ill check this soon as I can
Post #616327 14th Dec 2021 12:46pm
wayneg
I give up. You obviously know best. The fact that I have owned a TD6 and replaced both pumps on my car and a mates does not add any weight to my help. Best call the RAC again or better still take it to the dealers. Over and out. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #616331 14th Dec 2021 1:08pm
Jayk1993
Sorry not sure what I've said to upset you I don't know best thars why I'm on here asking for help I was simply explaining the it seems I have been investigating the wrong pump and will take your advice and look into this one
Post #616333 14th Dec 2021 1:31pm
