Thanks Dan,
Not a big deal, but my thinking was more related to any improvements in how the regenerative braking works in the new L460 PHEV variants. Having driven a L494 P400e for a month last fall, I don't think that the current LR PHEV recuperation system is best-in-class wrt efficiency. We tested and almost ordered a Porsche Taycan Cross Turismo last summer (but turned it down due to our hopes for the coming L460 PHEV model), and the Porsche recuperation system pulls up to 265kW recuperation power when braking, and it does that using traction on all 4 wheels. Of course much easier to obtain an efficient recuperation system in a BEV vehicle having electric motors on both axels…
However, I guess that the focus on efficiency for the new L460 has resulted in an even better recuperation system in the new L460 PHEV variants. But since the 4WD in new L460 is set up differently than the L405 (L460 is RWD when driven at normal speeds), and if the electric motor is still installed where the torque converter normally would be in the bell housing, I guess that either the iAWD system needs to switch to full 4WD instantly when the brake pedal is pressed (less efficient regeneration due to increased transmission loss while braking), or regeneration will pull power from one of the axels and braking the other axel is done purely by the brakes. As said – definitely not a big deal – the new 2nd generation PHEV system in the L460 should most likely be more efficient anyway.
