Home > Technical (L322) > Gearbox troubles
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Gearbox troubles
Hi
Have some gearbox trouble in a 4.2 SC
I bought the car with a knackered gearbox, the car moved forward/back but i didnt try it on the road, previous owner said it would do a few miles then loose drive, getting worse until it would do about about 800 yards and get warning messages and loose drive, cool down and could drive another 800 yards
So, as a quick/cheaper fix Ive replaced the gearbox from a low mileage car, new sump pan, filter, oil etc and put on the ecu from original gearbox. Starts and drives but soon started having flares between changes, eventually banging and lots of resistance at low speed followed by warning messages and safe mode, this was after about 6 miles and not exceeding 35mph
Another duff box? It has warranty so can remove and send back if it is but what else could it be? There is only 1 autobox specialist round here who charges about £75 to say the box needs to come out and a new one will
Be £3k
Might have to bite the bullet and do that but looking for some advice first.
Just find it strange that it seems to be having same issues with this box as the original
Cheers
Post #615220 7th Dec 2021 6:42pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
No real way too tell unless it goes to a gearbox specialist I guess. Could be something to do with the solenoids. Best thing be too get the ecu software updated and get any faults read and go from there
Post #615221 7th Dec 2021 6:50pm
dingg1
Austrin at tynemouth are about the best in your area for zf issues.
Post #615242 7th Dec 2021 10:14pm
winslo
So there has been a slight mis communication between me and my garage….instead of taking the tcm ecu out of the original box and placing into the new used box he has put the whole mechatronic unit in, hence having the original
Problem again!
He is changing it out and new oil so fingers crossed it will be ok!
Will report back
Post #615412 8th Dec 2021 8:45pm
