Home > In Car Electronics (L322) > Odd wire
Pogo
Odd wire
Hi folks
So, I was changing the GPS antenna (see separate post) and I had the rear part of the roof lining down slightly. I noticed something that I initially thought was a piece of sealer just under the back of the lining.
After I'd done the antenna I saw that this 'sealer' had fallen down, so I had a look at it. It went behind the rear trim. I saw that it wasn't sealer at all, but a small wire covered in what looked like a fabric. I traced it behind the trim and it was attached to the loom and it appeared to go into the loom near the fuse box.
I have attached photos to show you what it looks like and hopefully where it comes from. My question really is where should it go to (I assume somewhere under the roof lining)?
Thanks
Roger
Post #614896 5th Dec 2021 5:03pm
