Home > Maintenance & Mods (L322) > Suspension pressure voltage
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
Trying to work out why I keep getting normal height only messages almost
Everytime I change height. I have a full refurb kit from 4x4air seals to see if it improves the pressure throughput but the pressure sensor supply voltage is only reading 0.980v when it should be 5v. The feedback voltage goes up and down as the pressure increases/decreases etc. seems strange to me. Anyone with any ideas?
Post #614483 2nd Dec 2021 6:02pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi, have you cleaned all the connectors in the wiring loom? Most of these sensor arrangements are a wheatstone bridge comparison set up, so high resistance in a connector will give funny results.
Post #614507 2nd Dec 2021 7:15pm
Tattiepicker
I’ve not touched anything yet. Wanting to see if any experienced owners have had similar problem/fix. Will clean everything whilst I have it out to fit the refurb kit.
Post #614509 2nd Dec 2021 7:21pm
