![]() | Home > Technical (L405) > Climate control question. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1395 ![]() ![]() ![]() |
In addition to setting the temperature you can adjust the fan speed so it does not blow as hard. Climate control is best with the windows closed. Only Range Rovers since 1988 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7973 ![]() ![]() ![]() |
I just press the Auto button & it seems OK |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
In Auto the blower speed is related to how close the temperature in the car is to the temperature you have set. If you have different temperatures set on the individual controls that will affect blower speed. Opening windows, at this time of year, will keep the blower on for longer.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3871 ![]() ![]() ![]() |
I also set at 20 and auto and just leave it. The only thing I've noticed is that eventually the car feels cold so I need to move it up a little to 23 - never noticed the fan. I don't think I ever open windows other than to pay for my McDonalds breakfast. Geoff |
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 ![]() ![]() ![]() |
I've had this problem and in my case it's been caused by my young granddaughter playing with the rear a/c controls.
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 ![]() ![]() ![]() |
Worth noting that you can change the automatic fan speed from low>medium>high. |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Put air con in Auto and press sync on air con menu.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Do you have to turn "sync" off to allow people in the back to change the temperature themselves? What do I put here then? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 796 ![]() ![]() ![]() |
No. Their actions simply cancel the sync. |
And - possible daft question - do I have to turn sync back on, or will adjusting the driver's temp do this? What do I put here then? |
Passenger action cancels sync. So yes, a new sync press is required. |
Thank you. What do I put here then? |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 ![]() ![]() ![]() |
This made me smile, when I purchased my 2014 a few years back I clearly remember how my heart sank when I got home, sat in the back and discovered the entire rear heat/cooling control & display panel was stone cold dead..!! I read the manual with vigour hoping to find it was just a matter of selecting some or other function but alas no such luck... So being unable to sleep I got around to stripping the rear control panel which was surprisingly easy to do, only to find that my 'fault' was a completely disconnected plug.. Quick reconnection brought all the controls back as they were meant to be.. Turns out the previous owner had young kids too, and while the fattie was not used much, I guess he must have got tired of them playing with the buttons back there... |
