Home > Technical (L405) > L405 4.4SDV8 B12A6-13 (28) Auxiliary heater water pump fault
Martyn
2013 Range Rover Vogue SE SDV8 Aintree Green
Hi all,
I picked up an L405 4.4 SDV8 a month or so ago and recently got the restricted performance warning on the dash, a quick scan with my IID tool showed no engine faults but a fault under HVAC for B12A6-13 (2Cool Auxiliary heater water pump - general electrical failure - circuit open.
The car runs and drives fine once the code is cleared but I'd rather get it resolved, however there seems to be very little info on the pump on the SDV8 vs the pump on the older L322.
Anyone had this fault before and did replacing the pump actually resolve it?
Thanks in advance,
Martyn 2013 FFRR Vogue SE
Post #613875 26th Nov 2021 3:33pm
It’s not the same unit as the 322. The Webasto unit was replaced with an erbspacher one. There is much less on them as they seem to go wrong less…..
If you download the WM from the wiki there is no doubt some info in there. It shouldn’t affect the car too much as it’s only the preheat and cabin warming that will be affected. There is nothing that can't be fixed with a hammer😜😜
Post #613947 27th Nov 2021 11:25am
Martyn
Thank you, I did some digging via Topix and managed to find some info on replacement etc so have ordered a replacement pump (LR039070) for around £140. I've checked all the electrical connections and they seem find so pump is the next step. 2013 FFRR Vogue SE
Post #613951 27th Nov 2021 12:00pm
Crasher73
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
Hi Martyn,
Did replacing the pump solve the problem? I have the same fault code and no working timed climate!!
Cheers
Mark
Post #650293 9th Dec 2022 4:56pm
Martyn
Hi Mark,
Yes, I've not seen the fault back since.
Thanks
Post #650296 9th Dec 2022 5:18pm
Crasher73
Excellent 👍🏻
I assume your fbh wasn’t working due to the faulty pump? Also, was it a fairly straightforward job to replace?
Cheers
Mark
Post #650298 9th Dec 2022 5:35pm
Ukandrewf
i've had this issue also. Do anyone know if the failure is a mechanical issue generally? My warranty company fighting me on it. Warranty Wise.
Andrew --
On my third Full Fat RR
Post #708881 11th Jan 2025 7:50pm
comports
I had the same issu on mine - FBH would fire up but never warmed up. Turns out the pump for the FBH had failed - mine was replaced under warranty and its been fine ever since. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709048 13th Jan 2025 11:55pm
Ukandrewf
Who was your warranty with?
Was it the aux water pump that had failed?
Was it a mechanical issue for warranty to cover it? --
Post #709050 14th Jan 2025 12:23am
comports
Hi Andrew,
I had a used car warranty through RAC.
It was a mechanical failure with a seized aux water pump which was replaced. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709057 14th Jan 2025 9:04am
Ukandrewf
thanks - precisely the sort of problem I'm having - the aux water pump has 'seized', and they're using that one word to say that it's not mechanical but somehow corroded or rusted shut. Fulls service history with correct liquids used etc. They're impossible. --
Post #709061 14th Jan 2025 10:46am
