![]() | Home > Technical (L405) > How to remove air sensor trim |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 796 ![]() ![]() ![]() |
This should help:
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Hi, this is easy to take off the trim, It is just held on with metal clips.
Tizzy Member Since: 07 Aug 2021 Location: Leicestershire Posts: 15 ![]() ![]() ![]() |
Thanks to all. Trim came off and went back on fairly easily using the pull the clip off suggestion. Also useful opportunity to clean the sides of the LCD screen. The temperature sensor fan was operating and clean so that’s not the cause of my cold air problem unfortunately 🙁 2015 3.0 TDV6 Autobiography in Santorini Black with black-pack
