Home > Technical (L405) > Deployable Steps suddenly stopped operating
I'm almost certainly just being a numpty but I need help to understand why my deployable side steps suddenly stopped operating. They've been working fine since I got the car. Then after the last wash, when opening the door nothing happens. I've done some searches on here and found a few things to try, with odd results.
Checked the 30amp fuse 39 in the load space box and all OK.
Looked over the dash and throughout the manual but couldn't find any reference to a side steps "button" anywhere - I don't think I have one...or do I??
Saw a post about a menu option and went there. I can switch them off and on there, but they don't operate in either setting.
However, I can switch on roof access mode and both steps deploy normally - and retract again when I switch off roof access.
So the steps work after all, but just don't deploy on unlocking or when a door opens.
Any ideas how I can get them set back to normal?? Mike - MPx
Post #613310 21st Nov 2021 5:27pm
There’s a button down by your right knee - below the boot release button
This may be worth a try -
Post #613315 21st Nov 2021 5:52pm
They will turn off if you press the TR2 knob... Could you have pressed this whilst cleaning? They will also turn off if the axle articulation is too great i.e. parking with one wheel on a kurb?
Post #613317 21st Nov 2021 6:02pm
Thanks Alistair...but I really don't think there is a button
 Mike - MPx
Post #613319 21st Nov 2021 6:09pm
There should be Mike... You have the wrong panel fitted there sir... Whistle
Post #613320 21st Nov 2021 6:12pm
And Craig wins the prize! Thanks very much matey - yes, must have pressed the knob as pressing it again reactivated them.
All sorted - help much appreciated. Mike - MPx
Post #613322 21st Nov 2021 6:14pm
Just to fill in the gaps, pressing the TR2 button means the steps won't deploy as you could be sat in muddy ruts... Thumbs Up Thumbs Up Thumbs Up
Post #613324 21st Nov 2021 6:17pm
ANOTHER one!!! Where will i put them all Shocked Shocked Shocked Laughing Whistle Thumbs Up
Glad its all working again Mike Thumbs Up
Post #613325 21st Nov 2021 6:18pm
Mikeinatruck
United Kingdom 2018 Range Rover Autobiography SDV6 Santorini Black
TR2 knob? whats that is it on a 2018 on? as my steps wont switch on... 2018 L405 Autobiograpghy
Post #692977 19th May 2024 4:32pm
Answered on another thread, but just in case someone stumbles across this one.
TR = terrain response and is the pop up dial near the gear selector.
Post #692980 19th May 2024 4:38pm
