Home > Technical (L322) > Terrain response working properly? |
DAW90 Member Since: 25 Oct 2020 Location: Dunoon Posts: 3 |
I rather think you've answered you're own question there with road tyres and wet grass. If they were all spinning at once, the centre diff wouldn't sense any great difference in speeds so wouldn't see any reason to lock the diff. Ditto for the rear diff as well. I suspect your defender has much more aggressive offroad biased tyres on which will obviously make all the difference. Wet grass + road tyres = zero traction and is the worse thing in the world with the wrong tyres. |
21st Nov 2021 5:01am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Were you in low ratio? GGS is not something I used often in my 3.6, but I seem to recall that Mud/Ruts and Rock Crawl only locked the diffs if low ratio was employed. Perhaps it's the same? The older I get, the more I realise that people confuse wrinkles for wisdom |
21st Nov 2021 9:25am |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 |
Yes was in low range. Will have to get some all terrains |
21st Nov 2021 10:07am |
