Home > General > VIN CODE - HPI HELP PLEASE....
Johnte
I've just bought a FFRR on eBay, done a HPI and everything comes up OK - but doesn't show as Range Rover, but as Land Rover 4x4 light utility ! is this acceptable..
Everything else- reg number, vin number, V5 number, V5 issue all match Ok
I'm collecting it tomorrow
Post #66533 31st May 2011 8:23pm
Johnte
Could someone possibly check the vin for me please..
Post #66534 31st May 2011 8:26pm
On my V5 it shows as Make Land Rover Thumbs Up
Post #66536 31st May 2011 8:28pm
pretlove
pm me the reg i can check that for you "RANGEISM WILL NOT BE TOLERATED"
Post #66537 31st May 2011 8:29pm
Post #66538 31st May 2011 8:32pm
Johnte
Does it also say Range Rover?
Post #66540 31st May 2011 8:44pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
my log book says:
Make: Land Rover
Model: Range Rover TD6 Vogue Auto Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66543 31st May 2011 8:51pm
Johnte
stu wrote:
my log book says:
Make: Land Rover
The HPI doesn't say anything in model, but it says light 4x4 utility under body plan.
Post #66544 31st May 2011 8:58pm
Johnte
pm sent - Thanks..
Post #66545 31st May 2011 9:01pm
pretlove
pm sent i hope that helps as i stated mine says model range rover "RANGEISM WILL NOT BE TOLERATED"
Post #66555 31st May 2011 9:44pm
johnson1
I've found this on some. It lists as '4x4 Light Utility' but this changes. It sometimes happens if the car has just come off a private plate or something.
Mine is listed as:
Make: LAND ROVER
Model: RANGE ROVER AUTOB TDV8 A
But:
A short while after registration it was listed on HPI as:
Make: LAND ROVER
Model: RANGE ROVER (LM)
There are also still no 'Year of Manufacture' and 'Engine Capacity' listed. I think this is all to do with number plate changes, first registrations. So don't panic.
Post #66557 31st May 2011 10:11pm
Lookers Park Royal
...... or it is imported and the DVLA office used to register it in the UK accepted a poorly completed form. Have a look at the PDI stamp in the service book which with quite possibly be stamped by a dealer outside of the UK.
Post #66559 1st Jun 2011 6:12am
