![]() | Home > Maintenance & Mods (L322) > 3.6 Gearbox Slip |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
If the fluid is black, you're going to need to change it and the filter - especially if it's never been done at 145k.
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 ![]() ![]() ![]() |
Thanks I am being told the e-clutch and some bushes have gone and it is a rebuild. 2009 TDV8 3.6 |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
Try changing the oil & filter and add a couple of doses of Doctor tranny, (instant shudder fix). If you have wear it wont fix it but will give you more time if the damage isn’t terminal. It’s not expensive and you just add it to your new oil when changing. I did mine at 100K after it started to shudder on hills while towing. I could have just been lucky as it went on to do 165K afterwards with just transmission oil changes every 30K ish.
Thanks Dave, I will try that. I have checked the oil with an infra red thermometer. Dr Tranny, right off to ebay. We only do a low mileage in the car so if I get another 10k out of it that is a win. 2009 TDV8 3.6 |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
whats the cause of this shunting between 1st and 2nd ? any ideas |
It is just a bit clunky not awful, a light shunt |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 999 ![]() ![]() |
The E-clutch is used only in 4th, 5th & 6th gears. The well-known “E-clutch issue” with the 6HP26 is caused by wear of the rear stator bush which doubles as a seal for the clutch hydraulic circuit. When it wears (because ZF experimented, unsuccessfully, with lead-free bushes for a while) the pressure escapes and the clutch slips. The symptoms are usually a refusal of the transmission to select any higher gears once it gets to the 3-4 upshift. That doesn’t sound like the symptoms that you were describing?
Phil |
No Phil drives quite nicely apart from the wavy tacho needle up hills sometimes, all gears work fine. The oil didn't look great for £120 for the Dr Tranny and an "oil change" it is worth a go. 2009 TDV8 3.6 |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 88 ![]() ![]() |
I don’t suppose anybody had any hints as to getting the dr tranny into the gearbox do they?! Without losing lots of oil….. |
If changing the oil you can just mix it in, if not, jack up the drivers side, (UK) and put safety stands in place. With the car on a good angle and engine running in park, gearbox cool, you can remove the filler plug and inject the Dr tranny straight in, not the best method as you should really change the oil as well but it would work. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Don’t just do an oil change, do a flush,you are only getting approximately half the old oil out, even changing the oil a couple of times means you are mixing old contaminated (with friction material) broken down/burnt oil.
