Home > Technical (L322) > Blend motors
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Blend motors
Have just got home my latest acquisition, a 2007 TDV8 VSE. 2 things I am needing to sort out pretty quickly and a search is not clearing things up. Firstly I have a clicking blend motor on entry and after switching engine off. Are they the same motors as on earlier cars like my old TD6? when that started clicking it was on entry only and much louder.
2nd issue is dash warning Water in Fuel. I have a very recent dealer invoice stating they have checked this out, no water found but fitted a new filter anyway. Can I just disconnect the wiring to rid the warning or is there more involved 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #607748 30th Sep 2021 3:55am
wayneg
Took blend motor out, disassembled, cleaned lubed and refitted and no more clicking. This was a couple of weeks back and no return of noise so jobs a good`n
Water in the fuel warning message, I removed the wire from the sensor, this is a single wire on a grip fitting that needs a fair bit of downward force to release it. No errors and no warnings since. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #612498 13th Nov 2021 11:04am
