Home > Maintenance & Mods (L322) > Rear Lower Wishbone Bushes
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Noticed today the front bushes on rear lower arms are shot.
Common issue?
I’ve seen you can buy complete arms for not a lot, I bet the bush is a pig to swap?
Post #611935 7th Nov 2021 8:15pm
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi . Replaced both on mine with two new nice new bushed pattern arms from Maltings. Believe me if you find that you have to saw the old bolts out, replace lower hub bush , replace drop links then the last thing you will want to do is replace the arm bushes. My ten cents. Ken ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #612098 8th Nov 2021 10:40pm
