Home > Maintenance & Mods (L322) > Rear shockies
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Rear shockies
How can you tell if one of your rear shocks has gone.
Seem to get a bit of a hollow type of sound from the arse end after going over various bumps whilst driving.
TIA
littlecub
Post #611267 1st Nov 2021 9:29am
JayGee
You will feel it when you drive it - unstable and bouncy rear end and frightening instability when cornering. 2012 TDV8 Vogue (L322)
Post #611277 1st Nov 2021 10:11am
Pawl
Possibly also oil traces on outside of lower damper housing - sometimes called oil misting.
This can be the cause of MOT failure if it looks "excessive". Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #611279 1st Nov 2021 10:16am
dhallworth
The ride on my car is a touch harsh and doesn't feel as smooth as the last SC I had so I'm about to change the rear shock absorbers.
If they're defective a dull thud could be possible but I'd suggest it's more likely to be a bush on the suspension or even the shock absorber mounting bush.
Might be wrong though Thumbs Up
Post #611306 1st Nov 2021 3:44pm
littlecub
Thanks for all the replies.
Have had a look at the bushes and they dont look too bad for the amount of miles on them.
I,ll get my garage to check them when I,m next in there to see if they need replacing.
littlecub
Post #611340 1st Nov 2021 7:42pm
