![]() | Home > Maintenance & Mods (L322) > Removable towbar - no keys! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7974 ![]() ![]() ![]() |
Got any pictures ?
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
My genuine swan neck keys eventually refused to play. Ended up unbolting from the armature and keeping assembly in garage. Not as if many folk will do an off the cuff towing job. Looks a lot neater at the rear end too. Previous cars:
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Don't think this one is a genuine LR one, but could be. Just defo don't have a key so I'll look at unbolting it I guess! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Get it unbolted, down to a locksmith n see if they can make you a key |
Wasn't aware that was a thing. Do you mean am actual locksmith or a place like Timpson? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7875 ![]() ![]() ![]() |
Errrr an actual real locksmith. A member of the Master Locksmiths Association should be able to make a new key…. Or pick it open….. or use a code stamped on the lock to cut a new key.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
1. Show picture, we can then maybe identify make
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If its a westfalia one some dealers have a full set of keys and can identify which one you need, or, I believe westfalia will send you a master set with a deposit for you try yourself. BMW i3 Electric Car
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 66 ![]() ![]() ![]() |
I'm not sure this will work on yours, being none original, but here's the story: I drove off with the trailer hitch not properly engaged. First bump, the trailer came off and the security cable snap-lock disintegrated. On its way back, what was left of the hook smashed the plastic wheel you would turn and pull to undo the tow-bar, taking the lock out with it. This left a smaller 3-spoke metal wheel which can be grabbed with pliers, twisted and pulled and the bar comes off. No key needed anymore. So, if your aftermarket bar is the same design, taking a hammer to that wheel might do the trick. 😉 |
KeithC Member Since: 16 Sep 2021 Location: Aberdeenshire Posts: 9 ![]() ![]() ![]() |
Perhaps not relevant if an aftermarket bar but I had a Westfalia with no key and stuck in the received. I removed the side plastic cover (opposite side to the handwheel) removed the circlip and drifted out the shaft 10mm. this allowed the handwheel to turn without a key. Took a bit of knocking back and forth to loosen the hook from holder as been there for a while but it came out.
