![]() | Home > Technical (L322) > Drivers door stuck in superlock |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8382 ![]() ![]() ![]() |
A post some years ago from our forum Guru....
Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
What’s the signs of a latch failing? Mine needs 2 pulls to undo from the inside but thought this was just a design feature….. 2012 TDV8 Vogue (L322) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
2 pulls means you have drive away autolock selected...switch that off and you'll only need one pull to open that door. ... - .- -.
Thanks |
You can turn it off in the menu on the dash... Pete
v8pete Member Since: 22 Oct 2021 Location: Cumbria Posts: 2 ![]() ![]() ![]() |
Thanks for your suggestions. I have now managed to get the door open without damaging it. I already had the door card off, fortunately, so I indulged in a bit of keyhole surgery. I removed, the cables, then prised off the plastic cover. Using a light and a mirror, I eventually found a lever which unfastened the superlocking manually using a long screwdriver. I replaced the lock unit so I can now lock the drivers door and rear offside door manually as the central locking only works the left side doors and the tailgate.
