Home > Off Topic - Other Cars > Towing Electrics Plugs and Sockets
noworries4x4
Yes I know this is a D4 question but I am putting it across all the Land Rover forums I am a member of.
Come on then all you clever people out there... does anyone know where I can get the plugs and sockets for where the towing electrics plug into the car loom. I want to make up some copy "Y" leads to feed the stop tail indicators on a beacon bar on the D4. I don't wish to "T" into the loom as I also wish to do some clever things with relays etc to make the lights flash alternately when escorting wide loads.
My local auto electrician has said a couple of his suppliers he was sure he could get them from has drawn blanks.
Come on clever forum people where do I get these from. If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #610966 29th Oct 2021 5:57pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Easy enough too find online mate. Look up emergency vehicle lighting on Google.
I guess regarding the lighting you can get some spade connectors and fit them to the end of the lights and then run a separate line to your light bar mate
Post #610989 29th Oct 2021 7:55pm
noworries4x4
Due to the Disco 4 MY16 being so heavily can bus I am trying to do everything post the tow pack ecu and don't fancy scotch lock bodges hence trying to find the correct plugs and sockets and making fly lead assemblies, yes a bit ocd I know If everything is under control you are not going fast enough.
MY 12 Full Fat TDV8
Post #610994 29th Oct 2021 8:15pm
