Home > General (L460 2022) > New L460 - Which engine to choose - Pros and Cons? |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
We have the P400 in a Defender 110 X which is identical to the new L460 version. It's a very good engine but has worse fuel economy than the 5.0 SC in the SVA...
28th Oct 2021 12:30pm |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 716 |
If most of your journeys are long distance then I don't think the hybrid makes any sense. Most of the time you will be lugging heavy batteries around that will be doing little other than blunting performance, dynamics and fuel economy. Hybrids only make sense if you are doing a lot of short journeys where you can run on electric most of the time and keep charging up at home or work. Also if you gain from any tax benefits. |
28th Oct 2021 12:40pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Not absolutely true, Hybrids make good use of capturing energy when slowing down / braking which can be used to get the tonnage moving again. BMW i3 Electric Car
28th Oct 2021 2:24pm |
This is true to a greater or lesser extent. However if your journeys are mainly ones which take you well beyond the range of the battery it's difficult to make a case for the hybrid being your best option. |
28th Oct 2021 2:55pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 824 |
Thank you Autobiography, 5.0 and AJGalaxy2012 for your comments.
28th Oct 2021 5:30pm |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 |
Because the PHEV option doesn't arrive until a few months after launch, I have ordered an early 4.4, with a view to swapping it for a P530e in the same spec. I'm guessing that the demand will be so high that I won't lose much.
29th Oct 2021 7:44am |
I am in a similar place. I have ordered the V8 but the 510e would probably be a more sensible choice for my regular journeys. I don’t want to commit to having a hybrid though until I have had a chance to test one properly because if the car feels lacking versus the V8 when the battery is empty on a long journey then it’s not worth it for me. I rather just stick with a V8 until they bring the all electric version out. |
29th Oct 2021 9:25am |
I’ve had a P400e for well over 3 years and 45k miles and can honestly say it’s the best car in the world. And the new one has double the leccy range and loads more power and torque. So it’s no gamble for me to commit to one. |
29th Oct 2021 9:32am |
The hybrid seems to polarise opinion which is what makes me cautious regarding one. Some owners rave about them and others can’t wait to switch back to a normal engine. |
29th Oct 2021 9:42am |
Thanks 5.0 - I'm going to go 4.4 V8 Petrol |
29th Oct 2021 9:43am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 769 |
I'd probably go D350 because I do regular long journeys and hate filling up, so it's more about the range than anything else.
29th Oct 2021 9:57am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 |
Great choice! I have the BMW 4.4 V8 in an M5 Comp and it’s sublime. I expect it would be easily tuneable in the RR, if desired.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
The early BMW N63 seems to have had an awful lot of problems, hence the revisions. |
29th Oct 2021 10:07am |
The S63 used in the M5 is not quite the same engine as the N63 being used by LR. The N63 is still a good engine though and is tuned to good effect by Alpina.
29th Oct 2021 10:44am |
